MSI Mob Over current issue
30 Oct 2014
Norfolk
So for some reason, I bought this new MSI ATX Motherboard, hooked it all up, no usbs are connected into the motherboard either.
Overcurrent has been detected on your usb device! Will shut down in 15 seconds to protect your mainboard.
Looked online and has something to do with a usb port..but none is connected so i cant see the issue from my side
Hi, so I can help you would you mind providing some more information such as the model of motherboard. Also are any of the internal USB headers connected such as the case USB ports? Some photos of the rear USB ports may also help and you may want to try reseating your motherboard as sometimes the IO shield can get caught in the rear ports which might cause this issue (I'm not sure about this but it's worth a shot)
