Hello
If I use a case fan that has a 3-pin DC fan connector on a 4-pin PWM fan connector/header that is on the mobo , will I able to control the fan speed with the bios our will they go full speed? & will a fan with 3-pin fan connector work on a 4-pin mobo fan connectors/headers
I will be upgrading my pc case with a fractal-design meshify c soon & it comes with 2x Dynamic X2 GP-12 fans. be nice to know if I need to buy any other bits to control the fan speeds.
Thank you for your time.
