MSI MPOWER MAX 8pin cpu connectors
13 Oct 2013
Dear all I've just build my new gaming system core components are as followed.
Case corsair obs 750d
Mobo z87 msi mpower max
Cpu 4770k
Cooler h100i
Gpu mdi 7950
Ram 8gig corsair vengeance 1800
Psu bequiet powerzone 750w
My question is
My motherboard supports 2x 8pin cpu connections but my psu only supports 1x 8 pin connection. Is there a cable of some sort i can plug in somewhere? So i can run power to the 2nd cpu 8pin connector. I have plenty of pci-e ports on the back of my psu..... Can i use Molex or perhaps sata power?
Any guidance would be welcome
Probably 5ghz plus with LN2! :p
Most people run with one 8 pin without issue with speeds in excess of 4ghz.
