msi neo2 fr
9 May 2007
hi my mobo is msi neo2 fr running
e2160 @ stock
8800gt@ stock
corsair ram @ 800mhz stock
but some times when i boot up it says that it failed to overclock!?? any one else have this board or the msi p35 plat which got this problem?
Have a look at the strap setting on this board, set it to 266 or 333 for overclocking, rather than 200 (default setting). It is a jumper on the motherboard somewhere.
This is a good idea - have you tried this?
Also, what ram timings are being set? Using CPU-Z to find out. If the timings are tighter than the RAM's rated ones then that could be what's failing.
Have you cleared the CMOS to make sure all settings are at default before doing things like the RAM voltage?
