MSI NEO4-F : Startup issues?
18 Oct 2002
Behind you... Naked!
When cold, it starts up fine.
Runs fine and never gives any problems at all ( Touch wood )
However, when I shutdown and restart, it wont start back up, until I physically disconnect the Power cable, or, if the PSU has a switch, I need to switch it off... Only for a few seconds, but then it starts back up just fine.
Not sure why its doing this?
I had thought it could be the RAM, but it does this with OCZ, Corsair, and Crucial.
I had thought it could be the BIOS? - Im on 1.D which is the latest, and I might try an older BIOS if I find it because it only started fairly recently and I upped the BIOS fairly recently, but did these 2 cioncide? - I dont think so, but you never know?
BIOS Setting?
Cant be because it never used to ,but does all the time now no matter what?
Hardware / Other cards etc...
With or without makes no difference.
Mobo simply on its way out?
I bloody hope not. My Asus A8N-SLI is starting to play up ( wont run a card in Second PCIE Slot without BSODs ).
Although the Mobo is 8under a year old, I dont want to have to wait 600 years for them to turn around and tell me its something stupidly silly.
