- 29 Jul 2020
I purchased this monitor as the Reviews for it and videos for it showed it in a light of being a very good monitor.
I have had this monitor for over a year now since July 2020, when I got it I did notice Ghosting but played with some settings which reduced the ghosting to where I could still see it but it was manageable.
Until recently I had been running it with a MSI 1060 6gb I thought maybe the ghosting was something to do with the graphics card and struggling with the games.
Recently I upgraded my graphics card (6900xt) and as you would expect increased graphics settings from low to High/ultra/epic and with these settings I would expect to see the HD graphics all the time but due to there being slight ghosting it kind of blur’s the HD graphics when things move but when movement stops you can see the HD graphics again.
I know fast movement can blur the picture slightly but I am also talking about you see the slight blurry movement happen in the menu screen of World War Z, Within WWZ you have the characters in the menu screen doing some actions, when they are fairly still you can see all the detail in the clothes and face etc but when they perform an action or slight sway the fine detail is blurry.
Even when moving my view around in the game I would expect detail to be fairly crystal clear with the FPS you get with a 6900xt.
I use the display port to connect the monitor with Freesync on, I tried a HDMI cable but didn’t notice any improvement on the ghosting.
I have changed the monitors settings from fastest to Fast and normal but this hasn’t helped much, fast seems the best setting.
The web page that has the UFO’s going across the screen you can clearly see the shadow trail.
If no one has any monitor settings to try should I be looking to return the monitor for a replacement if the warranty is still valid or replace the monitor for a different one?
Many thanks for your time.
McLeish
McLeish
