Hey guys,
I just want to know has any one had any issues using the OC genie feature ?
Long bit below
which should explain the issue i have had
Ok well i recently (3/4weeks ago) purchased this board along with
CPU - I5 750 +a Corsair H50
RAM - Corsair XMS3 4GB - http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS&groupid=701&catid=8&subcat=1517
gfx - sapphire 5870
psu is a Corsair HX 750w
case - CM storm sniper - http://www.overclockers.co.uk/showproduct.php?prodid=CA-185-CM
anyways installed it all ran fine out the box, and i decided to wait with using the OC genie feature until my pc had been running abit, its been on almost 24/7 since i got it.
CPU idel is 28-30
load after playing CoD MW2 for a few hours it got upto about 40-45.
(always with CPU/rad fan on 50%) case fans on lowest
so today i decided it was time to see if i could get a bit more for my money and tried using the OC genie feature.
Turned it back on and the screen didn't come on with the load screen image and it wouldn't boot so i couldn't get to the bios, it then restarted its self 2 or 3 times, I guessed it was trying to sort out the best settings then i just hung and didn't do anything so i tried to reboot and it just hung again.
So i turned OCg off and it booted up fine. went to bios CPU was at 57 with the CPU fan on full, which i know is well within the tollorance levels
So my question is to any one else with this board whos using this feature, and if they had any issues with it ?
Thanks for reading
Long bit below
gfx - sapphire 5870
CPU idel is 28-30
Thanks for reading
