MSI P67A-C45 issues
6 Nov 2004
This thing doesn't overclock at all. I've never had a motherboard that passes stability testing fine then BSOD's randomly when doing normal stuff. If the CPU can't handle the clock normally prime fails but this passes prime easily just BSOD's randomly.d I've set it to 4.6ghz at cpu volts well above what was require to initially pass it prime stable for 6 hours yet it still randomly BSOD's, anyone else having these issues? Also I can't get the EIST function to work either even if enabled or disabled via the bios and there is no C1E option in the bios.
Is there something wrong with my board? Should I try to RMA?
It's running with a I5 2500K and some G.Skill ram that passes memtest.
What BIOS version you running? V1.7 is the best so far. Before that I found vcore wasn't being applied from what I set in the BIOS. EIST working fine here, stable at 4.7GHz 24/7 @1.31V
