MSI P67A GD65 Bios problems
30 Sep 2013
Hi there
Sorry for reposting regarding this.
In a similar thread on the motherboard section there was discussion of another person having exactly the same problem as what i have with my motherboard.
I had to Flash my Bios on my motherboard to i think it was 4.2 or 4.3 to get my GTX780 to work, now i believe the first time i did the bios flash it went wrong and did it again and it went through fine, now i had the same flashing led as mine, but when i went into the bios to enable the auto bios update that worked fine, but then when that finished i get a red box appear on my screen saying the following messages:
Warning!!! Please insert to your USB.
then i get
WARNING!!! BIOS ME UPDATE....FILE NOT FOUND.* PLEASE ADD FILE TO YOUR USB
I have had a thread on msi forums going for a while and no one seems to know the solution and I am wondering if you guys know what I am missing or what file im missing, i cant get into the bios to change the boot order or nothing, is it something to do with Intel Managment Engine 7 that i need to sort out or what, im totally at a loss
If anyone does know I would be eternally greatful as it could Z77 and if so any recomendations on to what will work out of the box with a GTX 780 as i dont feel happy flashing the bios's on motherboards.
Many Thanks
subzie
heya all
total change of plan, I managed to sort it out some how, downloaded bios 4.34, unzipped it to a usb stick, and it was done so just disregard this panic post, all sorted :)
