- 13 Jun 2017
Hi everyone, i hope this isn't a repeat thread but i couldn't find this subject on here.
So i have an MSI R9 390 8GB Gaming. Definitely not a bad graphics card when it works correctly, however, Recently i've noticed low erratic frame rates. it runs call of duty 4 remastered at roughly 88fps but by the time i notice it has dropped to 10, 5, 1 then back up to 60 then 88 (guesstimate figures, i have no log file).
Attached are screen caps of msi afterburner graphs showing all the info i could fit on the screen.
This isnt a thermal problem as my temps are posted on afterburner and hold between 68 and 72.
I really hope there is someone out there who knows what i can do to fix it, or at least tell me straight that i need to buy a new GPU.
Thanks
http://imgur.com/28WwLel
http://imgur.com/pN0IVwu
UPDATE: I replaced the PCI-e power cable to my gpu and for the moment it looks stable-ish.
It still fluctuates when playing call of duty but the FPS doesn't drop to below 55-60 so its playable. Im not sure if that was what it needed but for now im happy with it.
Thanks for the support!
Thanks
