MSI Trident X display issues
30 Jan 2005
Inverness
I've got an MSI Trident X 9th gen system 9700k, 32gb RAM and it did have a 2080 but I've sold that and was planning putting something a little older in it until GPU prices settle down a bit the only trouble is I can't get anything else to output a display in it.
I've tried a titan X Maxwell and a GTX 780 both give a VGA error although I did manage one successful boot on the titan X somehow. When refitted the original 2080 it worked fine it also works perfectly with the onboard graphics.
This system has some sort of daughter board like a PCI-E riser but with other cable connections on it. Could it be some compatibility issues with that?
The bios is also quite old but it seems to take a different bios to the stand alone motherboard one z370i gaming pro carbon AC so I'm reluctant to update it incase I brick it.
Just wondered if anyone can help?
Thanks
Scott
Do you have a picture of this other board? I'm not familiar with Trident X systems, but some risers have sockets on them for power etc. It's possible that the riser is defective or isn't drawing the right power for some reason.
