MSI wind u100 dropping wireless, desperate help....
20 Oct 2002
Bromley
I have two of these, and both keep dropping the wireless connection no matter how strong it is. Ive tryed all sorts of drivers and settings but still dont seem to be getting to far.
They stay connected all day using external wireless, and no other wireless device is affected.
Ive posted on all the msi forums i can find, and while there are others with the problem, no one seems to have sold it apart from buying a different wireless card which kinda defeats getting a machine with one build in.
Can anyone help or have any ideas please!!!!!!!!!!
Have you disabled the power saving options for turning off the wireless..? I,m sure you have tried this but worth a go if not...
yes mate i have, for the time being ive installed windows 7 on one but i dont have another valid key for my other netbook. Wireless seems to be ok under that so at least i know its a driver issue.
Still need to sort the problem out on the xp one though.
Thanks
must have been a driver issue, ive just installed windows 7 on it and its running like a dream
