MSI X570 TOMAHAWK WIFI - BOOT LED ON
29 Dec 2020
Hello, i've recently done my first pc build. Everything went smooth until when i actually tried to use it.
SPECS:
X570 MSI TOMAHAWK WIFI
RYZEN 5 5600X
CORSAIR RM750X
16 GB CORSAIR LPX Ram 3600
and a GTX 970
I thought the flash bios went ok, because it took around 7 mins and the pc powered down. But the BOOT LED light won't go off, and i can't go into BIOS.
Any advice?
Can you try the bios update again via usb? I've seen videos online of updates being performed with everything plugged in so I think you should be able to perform an update
It works! For anyone having my same issues, for some reason the display port cable wasnt reconised. So i plugged in an hdmi cable nd it boot me to bios.
Thanks for the help
