- 11 Dec 2005
- Cheshire
Krypton X79 810i Intel Core 3930K 3.20GHz @ 4.40GHz DDR3 Overclocked Bundle @ £959.99 inc VAT
Designed by experts the "Krypton X79 810i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton X79 810i" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
Bundle Specification
- CPU: Intel Core 3930K 3.20GHz @ 4.40GHz CPU
- Motherboard: MSI X79A-GD65 Intel X79
- RAM: G.Skill RipJawZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel
- Cooler: Thermaltake Frio Advanced CPU Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £959.99 inc VAT.
PRE-ORDER NOW
Krypton X79 870i Intel Core i7 3960X 3.30GHz @ 4.40GHz DDR3 Overclocked Bundle @ £1,399.99 inc VAT
Designed by experts the "Krypton X79 870i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton X79 870i" will accelerate your computer experience into the next level.
- CPU: Intel Core 3960X 3.30GHz @ 4.40GHz CPU
Service Package
Only £1,399.99 inc VAT.
ORDER NOW
Service Package
PRE-ORDER NOW
Service Package
ORDER NOW
