MSI X99 SLI Plus Overclocking help?
Permabanned
8 Nov 2003
Yorkshire
I have built my new PC and tested it over the last couple of days. Time to overclock beyond the OC Genie button but how?
The CPU Ratio and BCLK is locked in the BIOS. I have the 5820k so should be no issue there. Any ideas? I have looked around on the net and no one else seems to be having an issue so it must be me missing something simple!
I just want to run at 40x100MHz for a 4GHz OC.
Thanks.
Sorted it, you just type in the box lol. Happily running at 4.2GHz now.
There's nothing to indicate what you do unfortunately.
Well, that was easy.
Set multi to 45, vcore to 1.3. Done.
Seems to max out to around 75c in Aida. Might try to decrease the volts a touch and see how it goes.
