MSI X99a Sli Plus memory issue
15 Dec 2008
Hi all, just built a new PC, all seemed to go smoothly, I had the memory in slots 1 3 5 7 as per the manual for quad channel. It posted first time. I had a look in BIOS etc, CPU temps were good, changed a couple of boot orders, saved the changes then it wouldn't post again. kept boot looping, no signal on the screen
I tried changing the slots to 1 2 3 4, no post. Tried just 1 dimm in slot 1, no post.
Then I reset the CMOS and put them back in 1 2 3 4 as per another forum post I found. it worked. got into BIOS, updated to latest BIOS.
for testing I then tried 1 3 5 7 again and no post.... put it back to 1 2 3 4 again and now I have windows 10 installed and boots fine....
Should I be worried? I noticed the box was battered when I got it which kind of annoyed me so worried it was RMA'd before and then sent to me.
  • Intel i7-5820K 3.30GHz
  • MSI X99a Sli Plus
  • Crucial Ballistix Sport LT 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit
  • Super Flower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - Black
  • Fractal Design Define S Midi Tower Case - Black Window
I have the same issue but i have the krait edition. This looks like a common issue with a msi board. I have rma mine. I would advise you to do the same
