11 Nov 2011 at 21:53 #1 dalehitchy1 dalehitchy1 Permabanned Joined 6 Sep 2011 Posts 1,726 so its build and i can get into windows... but every time i try and get into the bios it just stays on the loading screen. ???
11 Nov 2011 at 22:08 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare When it starts up, hammer the crap out of the del (or what it needs to enter) button.
11 Nov 2011 at 22:15 #3 dalehitchy1 dalehitchy1 Permabanned OP Joined 6 Sep 2011 Posts 1,726 i know to pres the del key.. when i do.... it freezes
11 Nov 2011 at 22:21 #4 nshire nshire Associate Joined 10 Mar 2005 Posts 696 Location Taunton just installed it myself today have u got access to another keyboard. I got a Logitech G510 and wouldnt go into BIOS. So had to use a G11 and worked. It is a common problem with the more advanced Logitechs with UEFI from most manufactors.
11 Nov 2011 at 22:34 #5 dalehitchy1 dalehitchy1 Permabanned OP Joined 6 Sep 2011 Posts 1,726 ah ok.. havnt got another keyboard other then my sidewinder x4
11 Nov 2011 at 22:37 #6 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Rough shot, try another clearCMOS.
11 Nov 2011 at 22:44 #7 Alex h Alex h Soldato Joined 13 Jun 2009 Posts 6,065 Location In the asylum update to the latest bios i had the same problem until i updated it Last edited: 11 Nov 2011
12 Nov 2011 at 00:00 #8 minimadmotorman minimadmotorman Associate Joined 11 Dec 2009 Posts 530 Location Barnsley I had issues with the wireless keyb I was using. Swapped to a cheapo usb and it was fine.
12 Nov 2011 at 00:20 #9 lrlcr lrlcr Associate Joined 24 Sep 2007 Posts 1,342 Location Oxford Does it just display a blinking cursor? If so what monitor and gpu are you running?
12 Nov 2011 at 09:51 #10 clone clone Soldato Joined 11 Jul 2003 Posts 8,168 Location Telford//west mids Hit the delete key just after the msi logo had this happen to me when i got it,also worth getting beta bios from msi forum.
