MSI Z68A-GD65-G3
25 Apr 2011
Crawley/Gatwick
Morning
I finally managed to piece together my sandy rig. Future proof with that board, planning on going to ivy once out. I've got couple of questions for those that know things :D
1. Is there a USB3 driver for when i need to install an OS from usb3? I downloaded one from the site but it doesnt work
2. in bios under pci latency timer, mine is 32, lower is better i presume?
3. I tried to setup virtu but the problem is, once a game runs its not the same resolution, its cropped basically, i run a single gpu rig, could anyone explain what do i choose for virtu settings (1920x1080 res)
4. Bios has loads of fancy settings, i was wondering do i need to enable some specific ones in order to benefit from them?
5. are both pci-e slots for gpu run at 16x? does it matter if i use one or the other
I think i didn't forget anything, cheers for the help
