- 20 Jul 2009
- The bleak North East arm pit of Britain
The MSI Z87 MPower is a fantastic board but seems to be over shadowed by the Z87X-OC and the Hero which are of similar price.
MSI have dropped bluetooth etc and in turn dropped the price to a far nicer £149.99inc. Nicely done
MSI Z87 Mpower SP Intel Z87 (Socket 1150) DDR3 ATX Motherboard @ £149.99 inc VAT
The MSI® Z87 MPOWER is the motherboard for those living on the edge. No other motherboard is tested more extensively and over a longer period of time than MSI’s Z87 MPOWER and that translates directly to better stability and higher overclocks for you. When overclocking, you don’t want a single component to limit you.
The new Z87 MPOWER comes equipped with the most impressive thermal design to date. The massive heat sink has been designed and tested to be compatible with any air or liquid cooler and SuperPipe technology maximizes the heat sinks efficiency.
- CPU Support: 4th Gen Intel® Core™ / Pentium® / Celeron® processors
- CPU Socket: LGA1150
- Chipset: Intel® Z87 Express Chipset
- Graphics Interface: 3 * PCI-E 3.0 x16 slots with 4th Gen Intel® Core™ processors, AMD CrossFire / NVIDIA SLI Support
- Display Interface: 1* DisplayPort, 2 * HDMI - Requires CPU Graphics
- Memory Support: 4 DIMMs, Dual Channel DDR3-3000(OC)
- Expansion slots: 4 * PCI-E x1 slots
- SATA / mSATA: 8 * SATA 6Gb/s, 1 * mSATA
- SATA RAID: RAID 0,1,5,10 - Available at ports SATA1-SATA6
- USB / IEEE 1394: 8 * USB 3.0, 8 * USB 2.0
- LAN: Killer™ E2205 Gigabit Ethernet
- Audio: 8-channel HD Audio with Sound Blaster Cinema
Only £149.99 inc VAT.
ORDER NOW
ORDER NOW
