msi z97m just up and running, 4790 question
19 Oct 2002
Yeovil
Have just got my msi z97m gaming up and running with a 4790k 8gb 2133mhz ram,r290 all on water
was after some advice ,settings etc to get most out of this cpu, been a while since I dabbled in any bios ,all I do know is oc genie ,causes random restarts at moment so avoiding that one !
any help appreciated
Q
Is the memory XMP profile set upso the RAM is running at 2133Mhz and not 1600Mhz?
CPU-Z will show you the current dram frequency (remember to times it by 2 as its DDR so it should say 1066Mhz)
I am not familiar with the BIOS on MSI Z97.
But somewhere I would think would be a list of Turbo boost values starting at 44X and decreasing down as each core is utilised till it hits say 41/40.
If you set all these to 44X then whenever the CPU is placed under load no matter how many cores are being used, it will be 4.4Ghz.
To prove this you can download SuperPI which is a single threaded application and while running a test (use a million or more places so it lasts longer than a few seconds) you should see the core speed reported at 4.4Ghz.
But if you get CinebenchR15 which will use all the cores you should see the max core speed shown as either 4Ghz or 4.1/4.2Ghz (again it depends on what the turboboost values are) at a guess.
So if you then set those Turoboost values all to 44X then rerun Cinebench and it should then say 4.4Ghz while running.
If it is not stable then set LLC (loadline calibration) to its max value.
If that doesnt work start messing with the Vcore
Thats not particularly tough RAM to run, XMP set should be working just fine.
I guess you could try seeing how old the boards BIOS is.
