MSN Beta
I don't have it, but i would imagine so, so long as you had two copies of the .exe and called them somethgn different.
Although the MSN servers you connect to may only allow once connection from your IP
not usually i you can run multiple instances on the same IP, since an ADSL typically has a single IP that it uses and you can have multiple users come from the same network, as for the instances, you could probably run something like GAIM and MSN at the same time, tried and test and works,
A[L]C said:
Is it possible to run two instances of MSN beta?
Thanks
It's an option called 'polygamy' in the MSN 7.5 version of apatch (http://apatch.tk). There's a version for WLM 8 Beta, so I'd be fairly confident the option exists in that.
Then, to open a second instance, just click the shortcut again.
EDIT: Looks like that link's duff at the moment. Try http://apatch.ikhost.com/
