msn messenger
2 Aug 2006
Liverpool
hi when im on a game people talk to me but because its full screen i dont know until i turn the game off, is there a way to make the keyboard flash or something when people start a conversation with me when im on a game
Usually a sound can be played if you get a message or something. Or just change your status to busy so people know you might not be immediately available.
MSN is set by default to change your status to Busy when you are running a full screen application, when your set as busy it doesn’t play the sounds when you receive a message. If you go into the settings and disable this setting you should be able to just leave your status as online and hear when people message you.
