MSN messenger
how about not singing in and quickly aborting it then sing in as appear offine. Otherwise yes you will pop up in the bottom left of their screen! unless they have turned notifications off!
how about not singing in and quickly aborting it then sing in as appear offine. Otherwise yes you will pop up in the bottom left of their screen! unless they have turned notifications off! or they are set to busy!
Stupid pedantic **** <3
ive just done it, your absolutely correct
