Hi,
My brother moved into uni recently and he's been having some troubles connecting to MSN as well as Outlook. I've had to set him up on Pidgin using the HTTP connection method for now but he doesn't like it very much.
I've tried most of the fixes that I can find on the internet for this error.
We're certain it's not the firewall on his PC, and it's not the Uni's firewall as other people in his flat can connect to MSN perfectly.
I was thinking it might be a problem with port 443 (HTTPS) or SSL connections as MSN, Outlook us them. I have checked and SSL is checked under the Interner Options.
He's using Vista Ultimate x64 SP1
He can connect to the internet and everything else perfectly.
Any ideas?
Thanks,
Craig.
Any ideas?
Thanks,
Craig.
