doesnt help your problem but if msn playing up you could try this http://www.meebo.com/ just sign in on your msn account and all your contacts will be there ,no mail though
i have had this problem with vista 64......this is what i have used to cure the problem...maybe ok for you guys as well
if the error message you get is this one Error: 81000306 the fix is this
4.a. Click Start, click All Programs, click Accessories, and then right-click Command Prompt and choose Run as administrator.
4.b. Click Continue when Windows requests permission to continue.
4.c. At the command prompt, type the following command, and then press ENTER: netsh interface tcp set global autotuninglevel=disabled
Note: This command disables the Window Auto Tuning feature.
4.d. After you disable the Auto Tuning Networking feature, verify if you are able to sign into Messenger.
