Msn Patches?
20 Nov 2004
Nock/Leicester
Hi all, im using the latest msn messenger and the a patch i used to use doesnt support it, so i now have all the crap back that i had got rid off.
Any way to get rid of it all again? Its there a patch that works?
not sure on the latest versions or anything, but i always used to use a-patch. don't know if they're still the standard. i always used to find that mess site such a pain to navigate
as previous post, ** looking for the "mess patch" for mess.be, if u are on about windows live messenger, it works on that to ;)
http://mess.be says:
General Options: 1.Enable Polygamy, 2.Remove Billing Information Menus ¹, 3.Enable Winamp Support For Now Playing Feature ¹, 4.Swap Now Playing Title And Artist ¹, 5.Distinguish Idle From Away Users (English Only), 6.Disable Spaces Integration In Contact Cards ¹, 7.Disable Nudge Protection, 8.Disable Nudge Window Shaking ¹, 9.Enable Multi-line Nicknames (English Only), 10.Add Sign-In Status In Systray Menu (English Only), 11.Remove Text Advertisement From Shared Folders Window, 12.Remove Display Pictures From Popup Toasts, 13.Hide My Sharing Folders From My Computer ¹
Main Window Options: 1.Remove Windows Live Logo, 2.Remove Messenger Title, 3.Add Always On Top Button, 4.Translucent Dashboard ¹, 5.Remove Display Picture In Sign-In Window ¹, 6.Allow Status Change When Signing In ¹, 7.Remove Bottom Links In Sign-In Window ¹, 8.Remove Windows Live ID Branding ¹, 9.Switch Tabs To Right Side ¹, 10.Open Display Picture Dialog Upon DP Click ¹, 11.Remove Display Picture In Contact List, 12.Boost Personal Messages To 500 Characters, 13.Remove E-Mail Button, 14.Remove Sharing Folders Button, 15.Remove My Space Button, 16.Remove Windows Live Today Button, 17.Remove Call Button, 18.Remove Colorize Button, 19.Add Sign-Out Button In Upper Panel ¹, 20.Add Personal Settings Button In Upper Panel ¹, 21.Move Add Contact Button To Upper Panel ¹, 22.Remove Add Contact Button, 23.Remove Sort Contacts Button, 24.Move Contacts Manager Bar To Bottom, 25.Remove Contacts Manager Bar, 26.Remove Yellow Infobar, 27.Remove Gleams, 28.Show Small Display Pictures In Normal View, 29.Show Display Pictures On Right Side In Detailed View, 30.Remove Emoticons From Contact Names, 31.Show Contact Status In Contact List ¹ (English Only), 32.Hide Personal Messages In Contact List, 33.Disable Song Links ¹, 34.Remove Advertisement Banner, 35.Remove MSN Search Bar
Conversation Window Options: 1.Add Always On Top Button, 2.Remove Yellow Infobar, 3.Remove Invite Button, 4.Remove Send Files Button, 5.Remove Video Button, 6.Remove Call Button, 7.Remove Activities Button, 8.Remove Games Button, 9.Remove Block Button, 10.Add Send E-Mail Button To Top Toolbar ¹, 11.Add My Received Files Button To Top Toolbar ¹, 12.Center Top Toolbar Buttons ¹, 13.Remove Webcam Icon ¹, 14.Remove Get Accessories Link, 15.Open Display Picture Dialog Upon DP Click ¹, 16.Hide Display Pictures By Default, 17.Remove Premium Services, 18.Remove My Dynamic Backgrounds Menus ¹, 19.Remove Bottom Text Advertisement, 20.Remove Advertising Space Area, 21.Remove Emoticons Button, 22.Remove Winks Button, 23.Remove Nudge Button, 24.Remove Voice Clip Button, 25.Remove Font Button, 26.Remove Colorize Button, 27.Remove Backgrounds Button, 28.Remove Packs Button, 29.Center Formatting Toolbar Buttons ¹, 30.Remove Send Button, 31.Remove Search Button, 32.Remove User Is Writing Message ¹, 33.Change Handwriting Tab Images To Text ¹
¹ = Mess Patch Original Feature
What's new in this version:
- Fully compatible with Windows Live OneCare.
- Added 'Show Small Display Pictures In Normal View' feature (super-flaming HOT).
- Added 'Show Display Pictures On Right Side In Detailed View' feature (requested by Daeron Tinúviel)
- Re-added 'Show Contact Status In Contact List' feature, although it's for English versions only this time. (Mess Patch Original)
- Added a new seperate option: 'Remove Advertising Space Area'. (by popular demand... very popular demand.... STOP SPAMMING MY E-MAIL :@)
- Important: Removing ads now stops both javascript errors AND flash sounds (reported by royeiror).
- Disabling song links no longer disables custom emoticon stealing. (Thank you Microsoft!)
- Fixed several bugs when saving/loading settings (although older settings files and registry keys no longer work).
P.S: To all of you Norton/Symantec users, you might have gotten a threat report indicating that Mess Patch contains Trojan.Zlob. Rest assured, this is a false threat. Mess Patch does not pose any kind of threat to your computer, and updating to the latest version is liable to get the glitch fixed. Downloading Mess Patch is always 100% risk-free.
hope this helps :)
I use the Mess.be patcher.
I have to agree with Sic though - their site is messy to browse.
I use mess.be patcher as well. Is it possible to remove the "non-instand messaging" group? It's really bugging me :mad:
