.Phnom_Penh said:People shouldn't be sending you music.
Phnom_Penh said:People shouldn't be sending you music. Messpatch will fix it for you though.
Try JMC777's fix first.david334 said:What option do i ress in Messpatch![]()
David334
Phnom_Penh said:Try JMC777's fix first.
Isn't it the RIAA?Macabre said:Why? you a member of the IRAA?
No, but illegal file sharing is something that shouldn't be discussed on this forumMacabre said:Why? you a member of the IRAA?
Deception said:I take it, it worked?![]()
The Mess.be patch or A-Patch for MSN have a disable MSN security feature so that you can send files over MSN without them being blocked.david334 said:Yep
It is a bit annoying going the the file right clicking and properties and going to unblock is there a way to totaly disable the MSN Security![]()
David334
