MSN Problem
Permabanned
14 Jun 2008
Suddenly my MSN thinks its fun not to sign into msn when i want it too. It seems to be having trouble connecting to msn, ive tried multiple emails and doen a connection test to which their are all green ticks here are some screenies. I really need to get on msn. Ive NEVER had this problem before.
here are some screenies:
wont sign in http://tinypic.com/view.php?pic=2zzrhwp&s=5
says im connected directly and thorugh a wired connection
http://tinypic.com/view.php?pic=1tlmv5&s=5
wats up with this, so random.
Sounds very much like something is blocking MSN, most likely a firewall! That would explain why you 'connection tester' suceeds as obv there is a internet connection just Messenger is blocked or the port it is attempting to use is blocked.
Try disabling your firewall or allowing MSN through...if MSN is already allowed through remove it and then re-add it if using a application based firewall.
Gary
