MsSQL Data Entity Relationship Diagrams
27 Nov 2004
North Beds
Hey guys,
I'm working with a small startup company at the moment and have been tasked at creating an easy to follow Data Entity Relationship Diagram from an MSSQL 2014 database. The devs use visual studio to look at data entity relationships, but even that doesn't give the visual representation that is clean enough for me to present to the non-technical folk.
Ideally i want something that will show relationship links column to column directly (similar to how Crystal reports shows joins if you build a report using tables), rather than just lines between tables like the MSSMS presents them, in an aesthetically pleasing manner, and ideally allows changes to be pushed back to the database or at least generates the update sql.
What tools do you guys use? Visio 2013 no longer supports connecting to SQL which is frustrating, and 2010 doesn't support SQL 2014. Google throws out a lot of answers, all of which look like they were last updated in 1995 and don't have free trials.
Many thanks,
Tom.
