EDIT: Ignore all that crap, I was making it far too difficult for myself, doing it in code now
I've got a bit of an issue that I really want to solve but can't work out if it's even possible. When I try it as outlined below I get an error saying subqueries can't be used, only scalar values.
I have a system where as a payment is inserted, I'd like to work out the commission payable on the payment.
To work out commission I need to run a few subqueries to find out a Rep's commission rate and the amount of commission paid to them to date. In pseudo SQL:
So the overall query I'm looking at creating would be along the lines of:
It's all rather confusing so I'm wondering if I'm even going about this the right way, can anyone shed any light on using subqueries in inserts in MSSQL?
Thanks for looking
Code:
Commission to Date:
SELECT SUM(commission) FROM Payments WHERE RepID = @repID
Commission:
@amount * (SELECT rate FROM Rep WHERE RepID = @repID) = commission
Rep Limit:
SELECT limit FROM Rep WHERE RepID = @repID
Code:
INSERT INTO [Payment] ([amount], [commission], [repID]) VALUES (@amount,
CASE WHEN commission + commission_to_date > Rep.limit THEN
commission + commission_to_date - Rep.limit
ELSE
commission
END
,@repID)
Thanks for looking
