MTA: San Andreas...
28 Mar 2005
Drunken badger punching
Hi all,
Am I currently the only person from OcUK playing this regularly? I used to see a few familiar names floating around the servers, but alas, nomore!
I can't remember when I first started playing. It was a while ago, way back last year sometime. I normally play on Littlewhitey's server, or if I get fed up with hackers, over at Team Neo 24/7 Cops & Robbers.
I predictably go by the name danza*, and generally pwn quite hard (still a bit gash at DM's though) :D .
So, call this an attempt at OcUK MTA:SA revival if you will. Perhaps I'll see some of you on there later.....? ;)
I stopped playing this when the MTA:SA UK server disappeared, but it is back up again now after several months, so i will return to the game soon. I went by the name Lazlow.
GFX707 said:
Is it still like it was where you could only race? Or have they made it deathmatchey now, or whatever?
Only racing. AFAIK SA:MP (the DM version) is full of hackers, well it was the last time I tried playing!
Johanson - I'm pretty sure I recognise your nick. I'll keep an eye open for you ;)
when it came out i got banned from loads of servers on the race one because they accused me of hacking
i tried to tell them using a ps2 controller and been a total GTA addict is not hacking but pfffft
holding up slightly on the analogue stick while on a motorbike for the win
are they still working on a DM version ?
ive never even played the old gtas in DM online :(
If you plug in a PS2 controller does the second analogue stick do anything? Ermmm, did it do anything in the PS2 version?
I still play this from time to time, Mainly play Neo's Cops and robbers server or littlewhitey's. It's good for a quick blast every now and then.
wizard91 said:
I never tried it, I head from people that it was full of hackers, and sometimes the cheatcodes worked. :confused:
Certain servers are regularly hit by hackers. Well, not that regularly. You can go a whole evening without on Littlewhitey's.
Some servers are rarely targeted by hackers. Team Neo tend to be pretty good in this respect.
If you're refering to the SA:MP servers, then IME, yes. Most are full of retarded hackers.
I can't play it as it says that i'm running v2.00 and it only supports v1.00. I reinstalled it and i get the same thing. I can't even remember installing a patch for it and can't find a v2 patch on the net :confused:
I'll try again and give it a full reg clean etc to clear out any old entries. Hope i can get it working.
I used to play in that server too a lot. The server dissapeared, and shortly after that my joypad refused to work in SA altogether (think it was conflicting with this Saitek keyboard I bought which Windows recognizes as a game controller). If the server is now back up I might try and have a game sometime.
