- 3 Dec 2003
- Sunderland
At the moment, I have:
Carrera Kraken 2001 frame (resprayed, aluminium, only v-brake compatible)
Suntour XCM forks (with lockout and preload adjustment)
Mavic Crossride front wheel
Mavic XM317 built on deore hub rear wheel
Deore cranks
Deore front and rear mech + shifters
Time ATAC pedals
SRAM 8 speed casette and chain
Specialized saddle
Club Roost handlebar, titec stem, m-part sports headset
Deore 525 front hydraulic disc
xt rear v-brakes
Panaracer fire XC pro tyres
It's currently on slicks because I use it for commuting as well.
I do XC/All mountain and think I've got a decent-ish specs for XC but it's struggling a bit on the all-mountain bits. The weakest bits are obviously the fork and the frame.
I now have about £150 spare (by selling the junk in my room on ebay) and think I should upgrade either my forks or frame or both.
What do you guys think? I'm going to get them second-hand. I think I can get some pretty decent forks for £150 second hand. I'm thinking about something that is air-sprung. However, is that necessary or would something like a tora 305 be fine?
Is so, I can spend about £90 on forks and £60 on a decent-ish frame, which also give me the option of upgrading to a rear disc brake.
To be honest, I'm quite happy with V brakes on the rear except for the hearing damaging causing squeal and the brake pads lasting the average of 2 rides but I want to know what you guys think.
Should I spend my money on something else other than frame and fork?
Thanks in advance
Deore cranks
Time ATAC pedals
Specialized saddle
xt rear v-brakes
Thanks in advance
