Mud guards for road bike.
12 Feb 2009
UK
Hi quick question.
I have a road bike that since fitting 25mm tires I have very limited clearance between tire and either the brake on the front and frame where seat post slides in at the rear.
I want to use this to commute on but really dont wanna get covered in crud off the road.
Any suggestions over the ass savers?
Edit: I already have some Crud racer mudguards that used to fit but now dont.
I just got a set of crud road racers mk3 - you probably have mk2.
they're pretty good and imo better than mk2!
I had to bend it a little to clear the tyre in the front as I have a max of 5mm between the tyre and fork.
I run SKS raceblade pro, can't fault them really! Initial setup was about 15minutes. The biggest advantage is they can be taken on and off the bike in less than a minute (once they are all setup)
