Hi,
Ive got a project that involves connecting via wifi to a portable ethernet device within a school. Connected via LAN to the device is a AP set to 'client bridge' mode. I can find loads of client bridges that I can use, and they work fine.
The only problem I have is that there are about 4 access points within the school, all broadcasting the same SSID. So I connect the client to the one with the stongest signal, and if I move away from that area I then tell it to connect to another, stronger singal AP.
The person who will be taking over the system from me is not really that computer literate, and wont have lan access to the client device. So if she moves into another part of the school, and loses, or gets a low signal, she wont be able to connect to another wifi point without getting into the device via ethernet.
Is there a client device out that will automatically switch between pre-configured access points? Going for the one with the strongest signal?
Thanks for any help. This would solve all my woes
