Multi-ATX Case
27 Aug 2003
North West, England
Hello,
I would like to build/buy a case that allows for Muti-ATX motherboards in the same chassis. I seen thermaltakes new offering allows two motherboards, but am after a chassis that allows more than that. Would like to combine my multiple computers and router, server etc all in the same box.
Any useful links would me much apprechiated thanks!
Regards,
Thomas.
custom, build. I have often thought about mounting my mini-itx linux file server inside my main PC. I thought it would mount up nicely on the side panel with it's drives in the correct places and it's external power brick in a spare 5 1/4 bay!
Did consider rackmount? But they arn't exacly good on the eye. And the rackmount case's i've seen are around £100 - 200 pounds. Abit OTT when i stick my P3 733 in there!
You wont find any decent standard cases to offer this, rackmount would be the only way to go, your into server territory with redundancy now so don't expect it to be good looking or quiet.
Why do you need it all in one case, surely a pile of 4 desktop cases on top of each other would be a much more economical way to do things?
