Hi all
Trying to spec a new machine which is mainly used for 2d applications (stock market trading and poker mainly).
The key requirement is being able to run upto 4 independent monitors at 1920x1200 resolution.
Currently I have an AGP based system which can run 4 monitors but only upto 1600x1200 reso and ive just upgraded a couple of my monitors to 24" ones.
It appears my options are either:
1) Short term solution find an AGP card that will run 2 screens at 1920x1200 (advice on suitable card gratefully received)
2) Build a new PCI-E machine which can handle 4 monitors at 1920x1200.
As far as budget is concerned ill spend what is needed but dont see the need to overspec the machine if im not gonna use its full ability.
I know which monitors I intend on having and have all the peripherals so its just the main unit I would need to replace.
My current machine has 2 high speed hard drives which ideally Ill be able to re-use (if I can), and also has Windows XP which Im happy to stick with, I think the rest will need to be new.
Would appreciate any advice, especially on what graphics card to use and what motherboard and processor to go with.
Thanks in advance for any advice received.
