Multi-Gb switches.
11 Oct 2006
Wiltshire
I currently have a Netgear GS110EMX which gives me two 10Gb/E but would like another couple of ports that can handle 2.5Gb. My ideal would be the Netgear XS512EM but the price of almost £700 puts me off a little. I could just about get by with a Netgear MS510TX at under £250 but wondered if anyone out there knows if there are any similar products from other manufacturers?
The MikroTik CRS305-1G-4S+IN has 4x10 Gbps SFP+ ports and 1x1 Gbps port and is around £125. SFP modules can be bought from fs.com for £57.60 each which are compatible.
But, unless I'm very much mistaken, they don't offer the flexibility of Netgear's Multi-Gb ports so aren't what I need.
What do you mean multi-Gb? They run at whatever speed SFP module you use. If you have a capable device you can use a DAC direct connect cable without the need for an SFP module.
I mean the ability to handle clients at 2.5Gb and 5Gb as well as 10Gb. These are becoming more common as they'll run happily over Cat5e cable.
