Multi-line textbox vb.net
20 Jan 2005
Whitley Bay
Hi there,
This is probably a stupid question so I apologise in advance.
I'm writing code to pass information from a multi-line text box to a new email message.
When testing, I can enter text over several lines within the text box but the data that is passed to the email message is all on one line.
Is there a way of retaining the formatting of the text?
TIA
Si
Need to look at your code to see where you are going wrong, there a a couple of different ways you could ensure newlines are maintained, seeing the code will allow us to choose the best option.
Not sure if it's a web page you're doing and it might not be what you need, but you could try doing a string replace on the textbox content:
Code:
Dim emailContent As String = yourTextBox.Text
emailContent = emailContent.Replace(VbCrLf, "<br />")
//code to send emailContent to your emailing code
This replaces the line feed characters present in the text box and replaces them with HTML break tags which the email should understand (you might need to specify the email format as HTML also).
