Hello all.
As the title suggests i m building a new PC on which i want to have a multi monitor setup ( 2 for now) and which i want to connect to an AVR to get my sound from a pair of Dali Spektor 2.
Before i bother you with asking for an AVR reccomendation to drive the Dalis let me give you a few details on the PC and how i want it setup.The pc has one RTX2070 gpu ( 3 DP 1.4 and 1 HDMI 2.0b out) and an Asus Crosshair VII mobo ( one SPDIF out , no HDMI out at all) on windows 10.I want to run the first monitor STRICTLY off the gpu and not the AVR to take advantage of the DP1.4 and the 1440p 144hz Gsync that i paid it for.Second monitor will be used as an extended display and will be @ 1080p or 1920x1200 max (60hz) ,so nothing fancy here.
Now the next logical step in my mind would be to connect the gpu to the avr through the HDMI .And here is where my worries begin.I ve seen multiple instances online of people claiming that they either have trouble getting this config to work or that the PC detects the AVR as a monitor and that impacts the performance of their main monitor but none had the exact same config as me ( most of the ones i found were feeding both the monitor and the avr through HDMI,or they were not on windows 10 etc.).Is it possible to make the HDMI out of my gpu feed just audio and not pass video too and therefore tax the gpu? Should i forget about the gpu and go through the SPDIF from the mobo?
Thanks in advance for reading through all that and for your time and effort.
