Multi monitor gaming pc
5 Aug 2013
I'm after a triple monitor gaming rig with a build date of mid September. Budget is flexible but along the lines of sli 780 as opposed to sli titan, though if 7970 were 95% as good I'd happily save myself £600.
Looking to play arma, rome2, bf4 infact pretty much want to be able to pickup any game and play in ultra settings at 1080p, so cpu should be capable. I may even use it for, god forbid, work type stuff so flexibility is great if the premium is low.
Would like 27" monitors if possible, looking at max £1k for the three. Need a spec for everything sans os, keyboard, mouse.
many thanks!
YOUR BASKET
3 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £299.99 (£899.97)
2 x Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card £279.95 (£559.90)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £179.99
1 x Gigabyte Z87X-UD3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £158.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £148.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £113.99
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x CM Storm Quickfire Rapid Mechanical Gaming Keyboard - Black Switch £69.98
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) £65.99
1 x Corsair Vengeance M60 5700dpi Laser Gaming Mouse (CH-9000005-EU) £51.98
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £48.95
1 x NZXT HUE RGB LED Controller - Black £39.98
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £39.95
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
Total : £2,800.10 (includes shipping : £32.90).
Did a bit of a re-vamp for x79 so I could get some good hardware in there.
YOUR BASKET
1 x Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £479.99
1 x Samsung 500GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE500BW) £289.99
1 x Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard £209.99
1 x XFX Pro 1000W Black Edition '80+ Platinum' Certified Modular Power Supply £149.99
1 x TeamGroup Xtreem LV 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) £119.99
Total : £3,171.16 (includes shipping : £32.90).
See that's why I hate setting budgets. You only ever go over them lol
Especially loving that case, not only for the looks but the cooling and the ability to wc the cards later if they're too damn loud and/or hot.
I know 120hz monitors are great but will the bezels be Ok with eyefinity on that one (can't see a bezel width)
Will sandybridge-e be worth the extra cost for gaming?
Three weeks is like a lifetime for me to mull over the final spec but that's an awesome point for me to start which is what I wanted so thank you v. Much :-)
The 120hz is more of a personal preference. Since you are spending that amount of money, it kind of seems silly not to get some. Unfortunately, I cannot find any thin bezel screens on OcUK for less than the monitors I'd spec'd.
Sandy-E is a great chip and if you get the basic chip & board, it's cheaper than Haswell. You also get the added bonus of Ivy-E later in the year. Since your budget was 3k, I decided to use it :D
Oppppsss........
YOUR BASKET
2 x Inno3D GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card £549.95 (£1,099.90)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor & Corsair H100i CPU Cooler Bundle £367.98
3 x Iiyama Prolite E2773HS-GB1 27" Widescreen LED 1MS Monitor - Black £199.99 (£599.97)
1 x Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £179.99
1 x Corsair AX860i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020037-UK) £179.99
1 x Corsair Vengeance K70 Mechanical Gaming Keyboard – Silver - Red Switch (CH-9000019-UK) £119.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9) £89.99
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9R) £89.99
1 x Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Red £64.99
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99
1 x Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - Red £14.99
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Single Pack (CO-9050001-WW) £13.99
2 x Akasa FLEXA FP5S 5 Fan PWM Controller (AK-CBFA07-45) £5.28 (£10.56)
Total : £3,318.74 (includes shipping : £32.90).
You could always drop the GTX 780's to 770's if you wished and bring it in on budget.
Actually just remembered that the PSU will not be seen so this is a bit cheaper :D
YOUR BASKET
1 x BitFenix Alchemy Cable Bundle - Red £28.45
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Red £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Red £6.49
1 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99
Total : £3,136.27 (includes shipping : £27.55).
Corsair Crazzzzzyyyy!!!!!
:( hopefully this is more to your tastes Snips
YOUR BASKET
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £179.99
1 x Antec High Current Pro 750W Modular '80 Plus Gold' Power Supply £119.99
2 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (TLAD38G2400HC10TDC01) £89.99 (£179.98)
1 x Alpenföhn 140mm Wing Boost Plus PWM Fan - Orange £14.99
5 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Orange £13.99 (£69.95)
2 x BitFenix Alchemy Premium Modding LED Strip - Connect White 12cm £9.29 (£18.58)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Orange £8.99
2 x BitFenix Alchemy 8pin PCI-E extension 45cm - Orange £6.98 (£13.96)
2 x BitFenix Alchemy 6pin PCI-E extension 45cm - Orange £6.49 (£12.98)
1 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Orange £5.99
1 x BitFenix Alchemy 8pin EPS extension 45cm - Orange £5.99
Total : £3,264.23 (includes shipping : £32.90).
YOUR BASKET
I need a shower, I'm now filthy.
Yeah, that poses a high risk of electric shock lol.
Got my eye on some slim bezel monitors, which I'm gonna add to that corsair build (+1 for themed). I'm just agonising over the price of sli 780's. Can't seem to find any benchmarks on multi monitor setups with 780's vs 7970's. All I've seen is a lot of speculation as to direct compute becoming massive post amd's console victory which is swaying me toward the cheaper option which after adding a couple of 2tb hd's should bring me in on budget. Stay tuned for electro pron :-)
Custom PC have just started benchmarking new GFX cards at 1920 x 1080 x 3, I currently run three 22" 1080p screens (LG IPS224) with a 670 2GB, only game recently I've had to turn down to work was bioshock infinite just to ensure that the framerate was as high as possible.
like this ??
YOUR BASKET
2 x Gainward GeForce GTX 770 Phantom 2048MB GDDR5 PCI-Express Graphics Card £359.99 (£719.98)
2 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99 (£149.98)
1 x Corsair Vengeance M65 Laser Gaming Mouse - Black (CH-9000022-EU) £54.95
Total : £3,050.09 (includes shipping : £43.60).
would look abit like this :D
OK complete GTX 770 corsair themed build including everything your going to need in order to pimp the thing out.
YOUR BASKET
1 x Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black £135.95
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
3 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£17.97)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
Total : £3,076.19 (includes shipping : £38.25).
god damn, this just arrived and first thing I clearly didn't pay attention to...
The fans are wrong, in the spec above both quiet and performance are listed. I'd assume I want the quiet ones but cfm is much lower. Please clarify which type (quiet/performance) should go on the front of my corsair 540?
AF fans the case the SP fans the H100, the only reason I spec'ed the SP Performance Edition fans then was because the SP Quite Editions weren't in stock.
