multi monitor resolution with certain software
10 Jan 2009
hi all, i use a prog called nuendo a lot (music production app) and i use 2 monitors so i can extend the program's window across them. the problem is that im getting a bigger main monitor but still wish to use a secondary one, when ive tryed using monitors with dif resolutions with the program, i could only make the window as big as the smallest resolution monitor could fit if that makes sense? the program doesnt appear to be like photoshop, where you can drag toolbars etc out of the main program area. is there anything i can do to get around this apart from changing the software lol?
look forward to hearing your replies :D
allready run that mate, doesnt seem to help although im not to sure about the limits or what it can do.
thanks for taking the time to reply though :)
Sounds like it's just how the program has been set-up; essentially all windows are contained within the parent window (which is the size of your other monitor).
A solution would be to buy a second monitor of the same size as the new one :p.
