Hi guys,
Don't usually come on here asking for help but now I'm a bit stuck.
Been looking into getting a 3 Monitor setup with the triplehead2go.
Was quite keen on the Samsung T220s but I read today that the monitors have to be able to run at 57hz in order to run the 1680x1050 (x3) resolution that the TH2G uses.
I've read that the T220s and the 2233BWs aren't compatible with 57hz, can anyone confirm this and if so, can anyone recommend a good monitor that would work with this setup?
Thanks in advance
Thanks in advance
