which is best to overclock is it using the Multiplier or FSB I did have it with 21*191 max temp 65c now I have it 20*200 4Ghz max temp 56c it stable with both but which one will give better performance it dose run with 20*220 4.4Ghz temps on load 63c but its not to happy with that but if I drop the multi down to 19 & FSB 230 4.370Ghz its happy. So my question is will I lose performance by dropping the multi and using the FSB to OC or is it better to keep the multiplier as high as possible.
Cheers
OTH
			Cheers
OTH
