Multi screen games, GFX cards and Cpu's
17 May 2003
Milton Keynes
I have a R9 285 and a I5-2500k running at 4.2.
Will the CPU be slowing the frame rate available, or does the GFX card carry enough "oomph" on its own?
[stupidly gave son I7-950 machine a few years ago....]
I know this is a bit open ended, but the power in GFX cards is much more than it was, so I have no idea at what point cpu bottleknecking happens......
That combo is massively limited by the GPU, not the CPU. Basically any desktop Intel CPU from SandyBridge up with 4 or more cores feeds any commercially available GPU as much as they can crunch and then some; this is particularly true for "multi screen" / high resolution, as in those scenarios you are always bound to be GPU-bound.
On the contrary to what you implied, GPU tech is lagging behind rather severely.
I always find the best way to avoid CPU being the limiting factor in most games is to add more screens/resolution/AA! Works for me, and sounds like you're thinking the same. :D
