- 31 Dec 2012
I've got to the point where it looks like I need a CPU upgrade.
I've been suffering poor frame rates and other glitches while playing Total War Rome 2. After investigating and my old i5 2400 is continuously maxed out across all cores, while my GTX 680 is barely hitting 80% at peak. I've also been having issues with my heavily modded Skyrim install, which I'd been putting down to the volume of mods I was running, but after checking, that too shows the same maxed out CPU with the GPU sitting below 80%
What I'm not sure about is what the most cost effective upgrade will be? I have about £200-£250 to spend realistically so I have two options.
Stick with my existing Z77 Mobo and buy an Ivy Bridge i7
OR
Upgrade to Haswell, but stay with an i5
Any thoughts?
Thanks
OR
Any thoughts?
Thanks
