Multimeter testing
2 Oct 2004
N.W London
Hi Guys,
How do you use a multimeter to test if a mains power cable from main socket to back of pc is working ?
Please help
Thanks
Did it come with a manual? Have you tried looking for one online?
It should be a case of putting it on the "check connection" setting, touching the probes to the right place and waiting for the buzzer to sound.
PK!
so are you saying it is possible to check the power cord using a multimeter?
if yes, I dont know where to touch the red and black probe..
obvisiously the cable needs to be plugged in...
can you use a multimeter to check if a laptop power adaptor is working??
if yes, where do I touch the red and black probe..
it cant be difficult surely..
manual is gibberish tbh cant find one online..
bingo...but where?
Touch one of the pins with one probe and stick the other probe in one of the holes in the other end of the chord. Try all 3 holes whilst keeping the other probe on the same pin. On one of the hole the indicator should change, indicating a connection between the pin and that hole. Repeat for the other 2 pins, if all 3 pins have a connection to one and only one hole then all is well.
It doesn't have to be. Its probably best that you don't test it while it's plugged in (due to your lack of experience with a multimeter, wouldn't want you to hurt yourself). So long as your just testing the kettle lead and not the transformer on the laptop power lead then the method I said will work.
what setting should the multimeter be on?
I have tried it with a mobile phone charger and laptop charger but cant get the meter to give a reading despite knowing both cables work..
surely its not rocket science..
i dont get it...
5.25 on the meter, what setting is that? 10a, HFE, or a side ways triangle???
what color probe should I use to touch the part that enters the mobile phone? which color should I touch the plug with?
pls clarify..
I appreciate its this / that test but I am a total noob so please spell it out for me..
thanks
