multiple actions from one click? (javascript question)
Permabanned
18 Jun 2008
Cannock
hi :)
if you have a js command on a click:
Code:
onclick="Effect.toggle('divID', 'blind');
is it possible to do two things on that click whereas above it just does the one?
that command toggles the div with id "divID" up and down with a blind animation using the scriptaculous library, but what i would like to be able to do is use just one button to do a blind up command on one thing and a blind down thing on another...
is this possible?
Put this within script tags in the page head section:
Code:
function myfunc () {
   alert("command 2");
   alert("command 3 etc etc ");
then in your onclick event:
Code:
onclick = "myfunc();"
That is a guess but it should work nicely.
alternatively you could do just do the following
onclick="Effect.toggle('divID', 'blind');alert('Yeah BABY');"
basically just stack em up
they will run synchronously.
