Multiple AIO
14 Apr 2009
Cheshire
Hi all,
Got a Antec 920 on by CPU.
Want to get a Kraken x41 onto my GPU.
Take it chillcontrol wont interfere with the x41 CAM software? And visa versa?
Hi all,
They might do as they will all look at the cpu temp and not the gpu temp. When i had my triple aios i just put the cpu one as your meant to.
Both gou aios the pumps i just plugged into a psu connection so they went at full speed and the fans i had on a manual controller but you could put them to a mobo header.
Dont bother with software for the gpu one.
