Hi all,
My dad upgraded his iMac yesterday and I noticed he has his regular Applications folder located in / and then another Applications folder in ~/user/Applications.
I note the user/Applications folder is used on my MBP for steam games, which is fine. However on his iMac it seems like there are duplicates for almost every application, including the stock applications like Address book.
How's the best way to figure out which Applications he has been using and is it safe to delete the other copy? I.e. they're not mirrored and use the same data source are they? Would it be best doing a straight drag and drop or use an Application deletion program? Normally I'd use the later but I don't want it deleting data relating to the correct application too.
I want to resist working from a fresh, which is probably the best option, as it means messing with a lot of photography program settings that he has personalised.
Cheers for the help!
