- 9 Jan 2012
Hey all!
Hoped something like this wouldn't happen.
Anyway 3/4 days ago I was playing on my pc, just music inbetween the odd league game with a friend and I got a BSOD. Now this is my first one since building this pc back in January last year.
5960X (OC'd to 4.6GHz)
SLI 980TI Hybrid IChills
32GB Crucial Ballistix RAM
99x-pro MB.
Ran completely smooth from day one until the last few days.
Firstly I got an error with the BSOD saying ** BAD_POOL_HEADER **
Followed a few online things to fix it and tried again, worked for about a hour before getting another BSOD saying ** MEMORY_MANAGEMENT **
After following a few more online helptips I checked and found out that one of my RAM sticks if I place in a specific slot on the board (think it was A1) it didn't recognise it - however here's the weird bit.
If I put another slot of ram into that slot, it recognises THAT one, yet if I put the apparent faulty ram stick into any other slots... it recognises THAT fine. weird.
Anyway, I went with only 2/4 ram sticks (16GB) and that seemed to work okay for a hour or two before another BSOD.
This time saying ** IRQL NOT LESS OR EQUAL **
I found online that a full reinstallation of windows fixes it (along with others). So I burnt windows reinstall onto a USB and ran that, or tried... over 10 hours about 30 times, kept erroring at different %s.
Finally, I don't fully remember what difference I did but it reinstalled windows...and bugged with BAD_POOL_HEADER again... so did a full reinstall AGAIN.
This was last night, was working fine until about... 30 minutes ago (pc was on for about 6 hours) where it BSOD and said ** PAGE FAULT IN NONPAGED AREA **
Which if I recall from googling is to do with fault windows install and just needs to be repaired... so i put the USB stick back in, restarted pc, kicked open repair and instantly crashes and says " Windows Repair cannot fix this problem " ... nothing else.. other than try another option.
So I'm completely out of my mind now. I should also mention I've reinstalled every driver over the last few days encase it was one of those, taken apart my pc and put back together - eventually I'll get a BSOD again.
Atm it seems to go for about 10-60 minutes before it just crashes. All temps are below 40c.
anyone have ANY ideas on what to do...
99x-pro MB.
